lpg burns ~20°c less. how is this going to destroy engine ?
main point is to tune it properly, so fuel trims are exact same on both fuels.
I just want to make clear if adding gasoline has a benefit or not.
companies will produce whatever market wants.LiquidSI's ECU supports "parallel" gasoline injection, so obviously there is a reason for it.
flashlube was born before leadfree fuel... and is still in business today.
so much money can be earned on people´s fear.
i dont see any, just higher cost.I just want to make clear if adding gasoline has a benefit or not.
none original lpg conversions are using flashlube or fancy systems. that should tell the story.
