I put the $30 Mevotechs into a 09. It's still "working" after 2 years. Ride quality isn't great though.I checked online a bit. Not many good aftermarket options.
It’s a Honda, not a Rolls. Sorry; if Honda knew what they were doing originally they wouldn’t have had a recall on them.I mean, would you put RT43 tires on a Porsche to get more durability? Durability should not always be the first priority.
Thanks for checking…I checked online a bit. Not many good aftermarket options.
Yeah. I checked, none that I would consider. Some in case of emergency like Delphi, ACDelco.I put the $30 Mevotechs into a 09. It's still "working" after 2 years. Ride quality isn't great though.
Thanks guys for checking for me. This sure a was a scary experience see this black oil on my garage floor,…I am hoping that is the only problem especially since I just had my car at the mechanic last week!Yeah. I checked, none that I would consider. Some in case of emergency like Delphi, ACDelco.
Thanks so much Jim. My mechanic usually gets parts from World Pac, but I don't know if they have OEM parts? So I am hoping he will get them from the local dealerships.I have not looked, and do not have the part numbers, but I found that with my 2016 CR-V and my nephews 2013 Civic that often after you add in the cost of shipping, OEMPartSource has the lowest price for genuine OEM Honda parts and fluids. They do not supply part numbers so you have to know the part number before going onto there site if you want to get anywhere with them.
Often part numbers can be found by looking for a part on e-bay. Sometimes you can find part numbers on Bernardi auto parts. As a last resort I visit the local Honda dealer parts department for a part number. The one near me is extremely friendly and even will print out an entire page of the section of the vehicle complete with all the part numbers for free.
I am going to try with the online form to see if they will still cover it for me. One area of the TSB says 100,000 miles or 7 years after purchase. I am at the 7 year mark. I leased this car then bought it after the lease was up, that is how much I love it.My 2013 Pilot had the same leaking bushings (referred to as "compliance" bushings by Honda). They were taken care of by the TSB.
And BTW - nice garage floor![]()
Not sure about your climate, but they come off just fine out here....UPDATE!!! Please help!
So my mechanic finally got to my car at 5pm today and stated yes it needs a new compliance bushing. BUT he said that he has to replace the WHOLE control arm, because the compliance bushing is attached to that. He can't just take the bushing off, because it is attached to the control arm and sometimes when you take it apart because it is aluminum it will break or bend.
I am not sure, I believe you,... I am only repeating what he stated.Not sure about your climate, but they come off just fine out here....
It is held on the control arm with 1 stud and nut, the 2 bolts are holding it to the subframe/cradle. I don't like the smell of this, do yourself a favor and go to the dealer and let them look at it and give you a price. You may be shocked one way or another.UPDATE!!! Please help!
So my mechanic finally got to my car at 5pm today and stated yes it needs a new compliance bushing. BUT he said that he has to replace the WHOLE control arm, because the compliance bushing is attached to that. He can't just take the bushing off, because it is attached to the control arm and sometimes when you take it apart because it is aluminum it will break or bend. And the control arm being on there and rusted for 7 years is difficult to get off. So I have to replace the whole control arm and the bushing.
He said my car is safe to drive and asked if I wanted to take it to the dealership instead. He called a couple of dealerships and there is a shortage of the control arms and bushings, so he will put in an order tomorrow and then they will let him know the ETA. He said he called my dealership and they did not have them in stock. He knows they have to do an alignment afterwards and said he does not do them, but has a reputable shop that does them.
He said to me..."you did not say you wanted just the bushings replaced, I can do that, it is less in price,.BUT when I remove that part I may break the control arm,,..because those are compressed in that area.that area of the control arm is rusted in there for the past 7 years and if that is the case, then we have to order that whole part and it is on back order. As it is when I order it, I won't have an ETA until I place the order. They will find the control arm with the bushing in any close dealership and deliver it to me. The 2 dealerships close to us do not have it, it is on nation wide backorder and is in short supply".It is held on the control arm with 1 stud and nut, the 2 bolts are holding it to the subframe/cradle. I don't like the smell of this, do yourself a favor and go to the dealer and let look at it and give you a price. You may be shocked one way or another.
^THIS!!!It is held on the control arm with 1 stud and nut, the 2 bolts are holding it to the subframe/cradle. I don't like the smell of this, do yourself a favor and go to the dealer and let look at it and give you a price. You may be shocked one way or another.
I am not defending my mechanic, and I surely do not know anything about this subject,...but by replacing this piece as mentioned above, isn't it possible to bend or break the aluminum piece that is attached to the wheel? I think this is what the mechanic was talking about. That there have been some instances where this has occurred, and now they have to find parts take more time, and parts are hard to come by. I don't know, I am taking in all of your advice as well.^THIS!!!
So I just saw these on another website,...I did not know about them,...so you are saying these are not a good choice and I should stick with the OEM Honda ones,..?????I put the $30 Mevotechs into a 09. It's still "working" after 2 years. Ride quality isn't great though.
Aluminum control arms are on the majority of vehicles today.I am not defending my mechanic, and I surely do not know anything about this subject,...but by replacing this piece as mentioned above, isn't it possible to bend or break the aluminum piece that is attached to the wheel? I think this is what the mechanic was talking about. That there have been some instances where this has occurred, and now they have to find parts take more time, and parts are hard to come by. I don't know, I am taking in all of your advice as well.
