I have had this 01 Nissan Sentra in the shop 3 times now for the clunking I feel in the front driver side floor board. Bad strut is ruled out. Those are fine. I had the tie rod ends and bushings replaced because they were bad, but the noise is still there. My mechanic just test drove it but it’s been wet out so he had a hard time hearing it. He put it up on the lift and inspected EVERYTHING under the front and the only thing he can find that he said “might” be doing it’s the control arm bushing. He said the rubber around is degraded, but he can’t be positive. You can’t just buy the dam bushing, you have by the entire control arm assembly for 175.00. Should I throw one on, or wait until the sound gets so bad it would be impossible to not diagnose it properly? The car will make a series of clunking sounds when I throw it in reverse to back out the garage and going forward from speeds at idle up to 30ish mph going over irregularities in the road then it makes the same sound. Yah or Nay on the control arm bushing?
