Originally Posted By: engineer20
I see. Which fluid is better, I did a pan drop from a shop a few months ago, remember, because of the sheared bolt, and I used motorcraft merc v. I heard castrol trans fluids are good, the valvoline merc v isn't as good as the castrol but what about the amsoil? Amsoil has one for the newer trans which is mercon lv as well as toyota ws, whereas the older amsoil which they sell at this belle tire for 11.99 a quart, is toyota type iv (4) compatible as well as mercon v compatible. is that worth getting? it'd work in both the taurus and camry, and would it work well as power steering fluid, the amsoil, and would it benefit, or would it only benefit if I use it as trans fluid in the trans during the next drain and fill? I want to do a ps fluid change with the baster method this spring, would amsoil help, or is using motorcarft mercon v good enough? Thanks.
For your situation, whatever dealer sells you is the best, because that will be the right fluid instead of cheaper, better, last longer, "heard it is better", "will also work in". Stick with OEM until you know what you are doing.
You can buy exactly the amount of fluid you want by the quart for each car, instead of trying to combine them to use the same fluid in both cars.
Look at the cap of your PS fluid reservoir to see what fluid to use, stick to it unless you know why you want to do something different (which in your case you don't).
