Loud tick coming from engine???
Colorado
Once in a while I hear a fast loud tick noise coming from the engine of my 2003 5.3 Silverado. The dealer said it sounded like a belt. It ticks about 5 ticks a second at idle and if you rev it it will get faster with the rpm but dissapear quickly as RPM's go up. The dealer said the power steering pump needed adjusting but it still does this maybe once a week randumly for maybe 30 seconds and then is gone. A friend of mine said maybe an injector??? It does not effect the truck at all and has been doing this sence new and now has 12,000 miles on it. Dealer doesn't think it is a problem. Any ideas guys??? Thanks!
Hard to say without hearing it. A tick used to mean a bad lifter, but these days the fuel injection system makes a ticking noise too which is normal.
If it happens dependably, you certainly can tell if it is belt or accessory related by removing the belt and firing it up. If it is gone then you know. From where I stand (far away) it sounds like even odds to be a lifter that is leaking down, no big deal and will probably heal itself with good oil changes.
It is not piston slap. the tick sounds just like when you turn on a gas stove or grill and the ignighter tries to light the gas...tic tic tic tic. It is VERY loud and you can hear it while in the truck. loudest thing in the engine when it does this.
I once had a car where the spark plug was not tightened properly after servicing. As the spark plug loosened in the hole, it started to make a ticking noise at each stroke. It would be an easy thing to check.
ChrisB,
Assuming you have sufficient oil pressure, is the noise coming from the top, sides, or bottom of the engine?
Another thing to check are the exhaust manifold gaskets. It appears you MAY be hearing the outrush of gasses immediately after the power stroke as the exhaust valve opens.
Or it could be carbon deposits in the combustion chamber getting impacted by the piston...
Common problem in the old Diamond Star cars (Talon/Laser/Eclipse) and not unheard of in the earlier Miata.
Combustion chamber cleaners will usually take care of it.
$0.02,
Robert
quote:
Originally posted by Chris B.:
Once in a while I hear a fast loud tick noise coming from the engine of my -*-*
Have you tried to get a better idea of the location...
Often times a LONG SCREWdriver placed on the engine in places with your ear to the end can tell where it is ticking, if no LONG Driver, then maybe a short 2-3 foot hose will work.
About once a month or more often if I had the free time I would take that puppy to the dealer service department and get it documented with as many service records as possible.
It is coming from the top area. I once pushed on the alternator and it stoped??? Maybe a coincedence but it does sound like it is coming right in that area and that is where the belt is also.
Could very well be the belts. Fords with the 4.2L v6 (mine) do that. Mine ticks like its gonna throw a lifter through the hood. Did it the day I test drove it (0.9 miles on the truck). I've heard plenty of other ones do the same. Funny thing is that when you open the hood you can hardly hear it. Close the hood and its back.
Check the idler pulley. I have had problems with it on two occasions. In one situation, the idler pulley had a bad bearing that was clicking and changed sounds as belt tension was changed.
In another case, the idler pulley's mounting bolt was loose. If this is the case, remove and put medium hold LockTite on it and retorque to about 20 Lb.Ft. I suspect this is the cause of noise.
Thank you for the help guys! It did it today again for maybe 20 seconds and got ticking really fast as my speed went up and then it just stops.
I have changed a belt but I have never had to adjust anything the belt goes around. What is the best way togo about adjusting these?
Ditto. Exactly well said.
first check with a big screwdriver and see if it moves, if it does, replace it, if not, then tighten the thing.
The belt tensioner on my Dad's Blazer use to do the exact same thing. Tick tick tick, sometimes quite loud. I installed a new tensioner, problem solved. Also, when you looked at the old tensioner as the engine was running, it would bounce all over the place while making the noise.
Engine noise from light trucks has customers suing GM
By AP
Owners of some of General Motors Corp.'s most expensive light trucks, including the GMC Yukon and Chevrolet Silverado, say the vehicles they paid more than $30,000 for may be worthless now because of loud, irritating knocking noises in their engines, lawyers tell the Free Press.
Thousands of vehicles, most from the 1999 to 2002 model years, may be affected, say the lawyers, who specialize in lemon law. They say GM is quietly buying back some of the vehicles.
Some experts say the knocking, caused by contact between the engine's pistons and cylinders, may be damaging the cars in the long run.
GM acknowledges the problem, which it said surfaced when it moved to a new family of engines, but says it does not affect engine performance and that it was corrected in later-model vehicles.
The problem is, there's no apparent fix for the earlier models, leaving buyers angry and worried. "I paid almost $35,000 for this truck. The truck is almost worthless," said Greg MacNeil, who purchased his 2001 Chevrolet Silverado two years ago. "In good conscience, I couldn't sell this truck to someone else."
When MacNeil bought the truck, he dreamed it would take him on long trips to northern Michigan.
But when his engine started knocking just two months after he bought it, he barely trusted his black pickup to take him 30 miles to work.
"I've been afraid to drive the truck up north," said MacNeil. "I only take the truck back and forth to work."
Ron Martiny of Oshkosh, Wis., had just returned from Florida in February 2002 when his Silverado's engine started knocking. His dealer told him the sound was normal. But a month ago, GM bought back his $40,000 truck, he said.
It's unclear exactly how many vehicles or how many kinds of GM vehicles have this noise, but customers and several lemon law lawyers say the problem occurs within months after customers drive them off dealer lots.
Lemon law lawyers say they occasionally get calls about engine knock with other automakers' vehicles, but they report an unusually high incidence of this kind of problem with GM vehicles.
"In the last year, this problem became really obvious," said Brian Parker, a Michigan lemon law attorney.
According to dealer service bulletins obtained by the Free Press, vehicles with the engine knock problem include 1999 through 2002 Chevy and GMC pickups and sport-utility models with 4.8-, 5.3- and 6.0-liter V8 engines.
The bulletins say that the noises are not detrimental to the vehicles, but experts say knocking is abnormal and can damage the engine.
GM officials say carbon and the amount of clearance between the piston and the cylinder wall are the primary causes of the knocking.
Usually, when the piston moves up and down in the cylinder, a component called the ring land, which is near the top of the piston, does not come in contact with the cylinder wall. But when carbon forms on the ring land over time, the ring land gets wider and begins to hit the wall. When the two come in contact, the driver will hear the knocking noise, said Chris Meagher, assistant chief engineer for GM's small block V8 engines.
Spacing is also an issue, because when there's too much room between the piston and the cylinder wall, a greater amount of rocking can occur and can cause more noise, experts say.
GM spokesman Tom Read said GM has addressed the issue by making design changes to the piston in some 2002 vehicles and all 2003 vehicles with the noise. GM has cut the amount of space between the piston and the cylinder so that the amount of rocking is reduced. The changes also keep the ring land from contacting the cylinder wall when carbon builds up, Meagher said.
Read said the knocking issue came about when GM started making a new family of truck engines in 1999. The company, however, vows that the knocking won't cause any damage to the engine because the carbon that has formed on the ring land isn't hard enough to damage the cylinder wall.
"Current analysis of 150,000 mile- and 300,000 mile-engines that have exhibited cold start noise show no significant wear," Read said.
And despite the controversy, GM's trucks got high marks in J.D. Power and Associates' 2003 reliability and dependability surveys. The Silverado, for instance, ranked second in initial quality in the study's full-size pickup category.
The noise, nevertheless, is irritating to consumers who have spent so much to purchase the vehicles.
"It's embarrassing," said MacNeil, who is suing GM. "If you accelerate, you can hear this vehicle 100 feet away."
There's also a question of durability.
While it remains unclear whether this knocking causes damage, lawyers and consumers say the piston's contact with the cylinder wall can't be good.
Knocking, for instance, has been known to cause damage to the piston, and in some cases it has resulted in premature engine wear.
Martiny, who bought his Silverado in February 2002, said he took his truck to the dealer after he noticed the knock and the service manager told him the sound was normal.
Then, in July of that year, the dealer talked to a GM customer assistance manager about the problem and later that month, Martiny got a letter from GM's Chevrolet division offering him a 100,000-mile warranty.
But Martiny said he didn't want the warranty because he planned to drive his vehicle far beyond 100,000 miles. He sought legal help in early 2003, and shortly after the automaker came with a $3,000 settlement. Martiny turned the money down.
According to Martiny and his attorney, Vince Megna, GM finally bought back the truck about a month ago. The company paid Martiny's $20,000 loan balance, plus another $20,000 and took care of his attorney fees.
Lemon law lawyers say this process is typical. GM usually offers consumers a 100,000-mile warranty to settle the matter. And when that's not good enough, the automaker offers consumers some sort of cash settlement for the noise, which can range anywhere from $2,000 to $5,000, according to consumers and lawyers involved in the cases.
When the cash doesn't resolve the matter, GM usually decides to buy the vehicle back, Megna said. Megna said the cases usually don't even make it to court.
"They know when these are filed, they aren't going to win these cases," said Megna, who practices law in Wisconsin.
Dan Powell, who lives near Orlando and owns a 2001 Yukon XL with an engine knock, was so incensed by the knocking that he created a Web site, www.pistonslap.com, that discusses the engine problem and seeks feedback from others with the issue. Powell is also suing to get his money back for the vehicle.
GM's Read said the company is working with angry consumers on a "case-by-case basis." Read wouldn't comment on any litigation, but said the knocking only affects "a small percentage of vehicles."
Read also wouldn't confirm or deny that the company is offering warranties, cash offers or buybacks for the vehicles.
What a consumer gets for the problem really depends on how hard they're willing to fight, lawyers say.
A lawsuit is generally the only way GM will buy the cars and trucks back, Megna added.
"GM has always bought the vehicle back, but only after being pushed," Megna said.
Clarence Ditlow, executive director for the Center for Auto Safety, said GM's stance on the issue is not surprising because repairing all those vehicles would cost millions of dollars. And if the defect doesn't cause a safety or emissions issue, it's tough to get a national recall.
The National Highway Traffic Safety Administration says it doesn't even track these sorts of problems because they aren't safety-related.
Consumers who have this problem should contact a lemon law attorney, Ditlow said.
"If you have a service bulletin, you're no longer arguing about whether (the vehicle) is defective," Ditlow said.
Meanwhile, consumers, many of whom are loyal GM customers, say they're disappointed that there isn't a repair for the problems.
"I would love to have it fixed if they have a fix," Powell said. "Except for the engine, it's a nice vehicle."
