Loud Engine Knock during Cold Starting
MN
Howdy,
I have a 2003 GMC Sierra, 5.3l with 96k on it.
I run 5-30 Amsoil, change it & the Wix/NAPA Gold every 6-8k.
During cold starts (0-20 below), the engine knocks loud for about 30 seconds, then goes away.
Engine runs & sounds great after that...
Any idea what it could be...?
Anything I could add to the Gas or Oil to reduce that...?
Oh yea, I better clear this one up - it is "Not" the Piston Slap issue. My old 5.3 had the piston slap.
This is a Knock - then it mysteriously goes away after 30 seconds...
Use a different oil filter at your next change. And, make sure oil level is topped off.
The 4.3L in my 1998 K1500 had a ~30sec cold startup knock like that. Piston slap can sound different from engine/engine. AFAIK, that truck is still on the road and doing fine.
Joel
I'm kinda thinking that it is a lack of oil also.
Just changed the Amsoil & from a NAPA Gold to a Wix - it did it on both the old and new.
You would think that the Amsoil should get the Oil around the engine as fast as any other oil, right...???
