80kHow many miles on the vehicle (engine)?
The sound you describe reminds me of the VCT failure on my Honda.
It was replaced under warranty, but it made the exact same sound as you describe.
Yea 1.4 T. That's not too thick? Calls for 5w30I'm assuming you have the same 1.4T that I had in my Chevy Cruze?
If so I'd give Mobil 1 0w40 or Castrol 0w40 a try and see if it quiets it down.
At 80K you're out of warranty and both of these Euro rated oils are excellent for your Euro designed engine (Opel I believe).
Na....the Quaker State Euro 5w40 is approx. 13.4 cst @ 100*C which is on the low end for a 40W....I'd guess the other 2 are similar. I'd bet that Opel designed engine originally called for a 40W in Europe. Remember that Chevy has to spec. a dexos1 oil and there are no 40W dexos1 oils to my knowledge.Yea 1.4 T. That's not too thick? Calls for 5w30
I’ve never heard piston slap last for a one second period. Takes longer than one second for the piston to expand on a slapping condition. Sounds to me like the initial rod knock some cars get before the oil pressure builds, or timing chain slap before pressure pushes out the plungers and tightens up the chain (if equipped). Usually either from excessive clearance or just bad filter’s letting the oil drain all the way out.
Do these conditions mean the end is near?I’ve never heard piston slap last for a one second period. Takes longer than one second for the piston to expand on a slapping condition. Sounds to me like the initial rod knock some cars get before the oil pressure builds, or timing chain slap before pressure pushes out the plungers and tightens up the chain (if equipped). Usually either from excessive clearance or just bad filter’s letting the oil drain all the way out.
Also could it be that the UFI filter with external adbv has failed?Do these conditions mean the end is near?
I thought this as well but without actually hearing it, hard to know for sure.I’ve never heard piston slap last for a one second period. Takes longer than one second for the piston to expand on a slapping condition. Sounds to me like the initial rod knock some cars get before the oil pressure builds, or timing chain slap before pressure pushes out the plungers and tightens up the chain (if equipped). Usually either from excessive clearance or just bad filter’s letting the oil drain all the way out.
sound like this?
Yes you are correct! The Chevy Trax, and Buick Encore started life as the Opel Mokka. Ironic that both models are now made in a plant owned by Stellantis......I'm assuming you have the same 1.4T that I had in my Chevy Cruze?
If it just started recently, I'd blame the filter's ADBVDo these conditions mean the end is near?
sound like this?
