- Joined
- Jun 2, 2003
- Messages
- 23,587
This is an Audi 2.8 liter V6 engine (not mine) with 134k miles on the clock:
A knocking sound started showing up a few months ago. The knock is pretty loud and it only seems to knock at idle. However, the 2.8 is very loud so it may still be knocking but you just can't hear it above 2000 rpm. The knock seems to be coming from the left bank of the engine and it seems to be knocking at crank speed. The engine will not knock if it is cold, it will only knock when the engine is at or near operating temperature.
When the engine is up to temperature and when the car is facing upwards on a slope of about 20° or more, the engine will not knock. However, when descending that slope the knock will start to come back as the car approaches level ground, and the knock will get even louder if car is facing down on a slope.
I was thinking rod or crank bearing issues, maybe excessive shaft endplay. I told the guy to rub some oil from the dipstick between his fingers to see if there are any metal particles that hint at bearing damage.
Any suggestions?
Any suggestions?
