Loose tolerance engine
Yuk
Edmonton, AB Canada
It is often said on the site that loose tolerance engines may benefit from a W50 oil and tight tolerance engines will do better with a W30.
How do i know if my engine has tight or loose tolerances?
The engine in question (a 1999 VW/Audi 1.8T) has used for most of its, 133,000 km, life Castrol Syntec 5W50 and has never needed make up oil. Not even a drop.
Currently, the engine is 1000 miles in on an Auto-Rx rinse with Penzoil 5W30 and still has used no oil.
Does this mean I have a tight engine?
I wanted to know the same thing in regard to my 2.8 Audi motor. A few people have claimed the 2.8 was on the loose side and a candidate for thicker (5W-40, 15W-50) oil. I even posted the bearing clearances on this forum, but nobody told me if those numbers hinted at a "loose or tight engine."
[ August 23, 2003, 06:42 PM: Message edited by: moribundman ]
Tolerances and clearances are two different things.
By the sounds of your post, you meant to say clearances.
I guess I meant clearances..... Any takers on this? I'd still love to know whether my car have big ones or little ones.
A general "rule of thumb" that I've read many times for journal bearing clearances in engines was 1 thou per inch of diameter.
Holds very close for many engines, built over many decades.
I checked the design bearing clearnaces for the turbines at work a few years ago (one designed in the late 50s, one designed in the late 70s.
The 10" bearings have 10 thou.
The 12" bearings have 12 thou.
No prizes for guessing what the 14 incher bearings have.
Here are the clearances for the VW/Audi 1.8T and the 2.8 (12v and 30v):
Main Bearing Clearance:
1.8T ---> 0.0008 to 0.0023" (0.02 to 0.06 mm)
2.8 ---> 0.0007 to 0.0018" (0.018 to 0.045 mm)
Connecting Rod Bearing Oil Clearance:
1.8T ---> 0.0004 to 0.0024" (0.01 to 0.06 mm)
Piston Ring Side Clearance:
2.8 ---> 0.0006 to 0.00244" (0.015 to 0.062 mm)
Connecting Rod Side Clearance (all engines):
0.0020 to 0.0122" (0.05 to 0.31 mm)
Piston Ring End Gap:
1.8T
top compression ring ---> 0.0079 to 0.0157" (0.20 to 0.4 mm)
second compression ring ---> 0.0079 to 0.0157" (0.20 to 0.4 mm)
oil control ring ---> 0.0098 to 0.0197" (0.25 to 0.50 mm)
2.8
top compression ring ---> 0.014 to 0.020" (0.35 to 0.50 mm)
second compression ring ---> 0.020 to 0.028" (0.50 to 0.70 mm)
1.8T
top compression ring ---> 0.0023 to 0.0035" (0.06 to 0.09 mm)
second compression ring ---> 0.0023 to 0.0035" (0.06 to 0.09 mm)
oil control ring ---> 0.0012 to 0.0024" (0.03 to 0.06 mm)
2.8
top compression ring ---> 0.001 to 0.003" (0.02 to 0.08 mm)
second compression ring ---> 0.001 to 0.003" (0.02 to 0.08 mm)
oil control ring ---> 0.001 to 0.003" (0.02 to 0.08 mm)
How do those clearances compare to those of other motors?
[ August 24, 2003, 05:15 AM: Message edited by: moribundman ]
In my Nissan SR20DET (1995), serivce manual states
0.0002" - 0.0009" (0.004 to 0.022 mm)
Connecting Rod Bearing Clearance:
0.0008 to 0.0018" (0.02 to 0.045 mm)
Piston Ring Side Clearance: 1.8T
top compression ring ---> 0.0018 to 0.0031" (0.045 to 0.08 mm)
second compression ring ---> 0.0012 to 0.0026" (0.03 to 0.065 mm)
Connecting Rod Side Clearance:
0.0079 to 0.0138" (0.2 to 0.35 mm)
There are lots more clearances I could post, but I cant be bothered typing them all out! As you can see, the Nissan SR20DET is a tighter motor all round compared to the Audi which suprises me, and the workshop manual recommends 10W-30 regardless of outside temps. However 10W-40 is the go in my engine, as its modified... (65% more power than std).
So it looks like Moribundman and I have loose engines compared to Leo's Nissan. Is there an industry average for these figures? Is there any correlation between these figures and oil consumption?
I get the feeling I posted all the data for nothing. There were people who ASKED me to post those clearances a couple months ago, and I did post them now for the second time. So far we got the blanket statement that all engines have had about the same clearances for the past decades, and we have data on one other make. Well, I can't tell if either one of those engines has loose or tight clearances. I can only see one is tighter than the other...
PS: Yuk, what are the clearances in your turbo? I suspect those are kind of important...
[ August 24, 2003, 03:24 PM: Message edited by: moribundman ]
I don't have the figures for the turbo. I'll do some research and find out.
I guess the clearance argument is moot then?!? If you don't know constitutes a tight engine then all the debate about heavy vs light weight oil, at least in relation to clearances, has been for not.
1996-1998 GM "vortec" 5.7 (most people here refer to Gen 1 SBC's as loose clearance engines)
Main bearing clearance
#1 .0007 to .0021
#2,3,4 .0009 to .0024
#5 .0010 to .0027
connecting rod bearing clearance
.0013 to .0035
Piston ring to bore clearance .0007 to .0020
Piston ring side clearance
Compression rings (both) .012 to .032
Oil control ring .0020 to .0070
piston ring end gap
Top compression ring .010 to .020
2nd compression ring .018 to .026
oil control ring .010 to .030
[ August 24, 2003, 03:51 PM: Message edited by: sbc350gearhead ]
These are the clearances for my Ford 5.0L Windsor V8 (1995) in metric, from workshop manual.
0.01 to 0.05 mm
0.02 to 0.06 mm
0.051 to 0.102mm
0.051 to 0.102 mm
0.254 to 0.508
#1 .0007 to .0021
#5 .0010 to .0027
.0013 to .0035
piston ring end gap
Can I safely assume that my 95 LT1 350 engine uses these same clearances?
Originally posted by Patman:
Can I safely assume that my 95 LT1 350 engine uses these same clearances? [/QB]
I can't say. The LT-1 is a gen 2 engine and is designed to spin to higher rpm and has more power than the vortecs.
LT-1 275-305 HP 325-335 ft lbs tq Redline
vortec 250-255 HP 330-335 ft lbs tq 5000rpm
[ August 24, 2003, 09:29 PM: Message edited by: sbc350gearhead ]
sprintman,
I don't know if others are posting clearances or tolerances. I posted the clearances of my engine, and I skipped the tolerances.
I posted clearances, if anyone wants more info, I will gladly post more. So far, the SR20DET is the tighest engine of these all!!! And I know in europe, 50wts are quite popular in this engine like the M1 15W-50!!
Just wondering, is an engine with tighter clearances generally a better built one? This engine is Japanese..
[ August 24, 2003, 11:52 PM: Message edited by: Leo ]
