Tiredtrucker - two totally different 'diesels', but I get your point and appreciate the input on sulfur. I have noticed the 6.0 runs noticeably rougher and down on power without cetane booster. My 7.3 ran the same no matter what.
roadrunner - It was the diesel tech at the dealer who told me every two weeks after I kept getting the WIF light on, even after changing filters. I change filters every 15k miles, which also drains the water anyway. Also, I use Rotella T6 and OEM Motorcraft filters, changed every 7-8k miles, going over 9k on the oil right now because I don't plan on keeping the truck. [/quote
If you were constantly getting the WIF light after draining the HFCM the sensor needed replaced, which isn't that uncommon. The importance of running the correct filters in this engine are extremely important, which you were doing. There is a place, dieselfiltersonline, that I purchased all of mine. Racor filters(Motorcraft manufacturer for the 6.0 & 6.4) were around $13 shipped to my door. I actually tried Rotella several years ago, wasn't impressed with the used oil analysis results or the pricing. There are much more economical choices available that return better used oil analysis results for the 6.0, namely 10w30. A synthetic lube isn't needed for longevity in the 6.0.
