Logic behind using 0W30 in a 0W20 vehicle
USA
I have a Crosstrek that requires the use of 0W20, but I wanted to know if it is recommended and safe to use 0W30 in the Crosstrek engine?
What are the pros and cons of such a move?
Why would you want to? The conditions that might warrant a higher viscosity lubricant are fairly well established. Which of them will you hit that would justify going higher viscosity?
Originally Posted By: Reddy45
Are you under your warranty period? If so, stick to factory spec.
Has anyone ever witnessed a case where a warranty claim was not honored because of (slightly) out of spec oil use? Ever?
OP - do you not have an owner's manual?
http://techinfo.subaru.com/proxy/114698/pdf/ownerManual/114698_2015_Impreza/MSA5M1513DSTIS_16.pdf
*: If 0W-20 synthetic oil is not available,
5w30 or 5W-40 conventional oil may
be used if replenishment is needed but
should be changed to 0W-20 synthetic
oil at the next oil change
I thought 0W30 was a step thinner in base oil viscosity than 0W20.
If so, 5W20 would be the next thicker oil, and 10W30 the next thicker after 5W20.
Synthetic or synthetic blend 10W30, might be your best next thicker oil.
No, but it exists in BITOG mythology
It's part of the same myth that the thicker oil works better.
I use what the OEM tells me to use but the I don't think that plus or minus one grade makes any difference.
My Honda spec's 0/20 so I ran the FF like 3500mi. and put in 5/30, it will never see 0/20, too many oil burning motors out there on x/20.
It's not about the owners manual or the warranty, although those things count for most folks. It's about the motor. You have to dig deeper. If the clearances call for 0.0015 for the bearings and the journals are less than about 1.75" diameter, you need a 20 grade oil. That's what fits the fluid space and is all that's needed.
If, OTOH you have 0.0025~35 clearances and your journals are around 2"~2.5" diameter you can easily run a 30 or even a 40 grade. The same holds for the wrist pins, cam bearings, etc. Modern motors out to about 80~100,000 miles are tight enough to run a 20 and get away with it. Beyond about 100,000 the clearances are starting to open up and a 30 grade is more in keeping with the fluid space ...
Sure, some folks go 20 grade to 175K and sell the car or truck. Me, I'm shooting for getting closer to 300,000 before an overhaul or a sale. so I chase the bearing clearances with viscosity. I do not want metal to metal contact in 99% of the engine. There are a few places like the valves and seat, the PCV check valve that you actually want a complete metal to metal contact. But not on rotating parts...
So use what fits the situation. That's why I always say listen to the motor with the hood up on a cold start after it has set for a week or so. If it rattles, clicks, clacks, or and knocks; your oil is wrong, or maybe your filter, or both ... A smooth quiet motor is a good goal. Won't always happen, but it's still worth trying
Just jump a couple weights right away and avoid the early unnecessary excessive wear...otherwise well said.
That's the 2.0 right? Doesn't Subaru recommend 5w30 for the turbo 2.0? Yeah...same engine and yes it may shear down but HEY guess what? Same clearances when new so 5w30 will work just great in OP's Subaru.
Subaru and the other auto mfgs carbon footprint is colossal, and their freaked about it, don't trust these stupid oil specs here and now they are are trouble.
I'm sure you could run a 5w30 without worry either...
Running 0w30 M1 in my Cobalt now...pretty much anything else I have ever put in it-it runs just fine on it. Not going to hurt it with pretty much whatever I dump in there, provided I change it on time.
The only issue I have with the 0w30 is the noise-it's going to drive me nuts! Trying not to pay much attention, but on the next oil change it's going back to 5w30....
