Liquimoly Motor Oil Saver
Running it again this go around but the proper volume for the 9qts takes.
Tigeo,
are you going to be using the mosvr every oci? The us rep on YouTube says specifically not to, every other change is his recommendation.
Anything that "thickens" oil is not something I would want in the sump during the winter months.
Disagree, if the end user is already using a synthetic oil this shouldn't be too much of a push; running out of oil is much more a concern. Lastly, if he commutes in a non severe environment or at least gets it running up to temperature plus 20+ minutes the difference will be minimal i would expect
