Liqui Moly Mos2 additive.
Great feedback NoTempoLimit thanks! Any chance you'd be able to post those in the used oil analysis section?
If not I'd be interested in the aluminum with/without MoS2 numbers if you don't mind.
Thanks KCJeep! Aluminum was unchanged at 4 ppm in both samples. BMW engines made for sale in the U.S. have iron cylinder sleeves. In the E.U. they use AluSil bores. For bore wear look a the iron.
At one time they used NikaSil which did not hold up against high sulfur U.S. gasoline and caused a lot of problems for them. So now they play it safe with iron bore liners.
Miles 3800 | 4068
With MoS2 | W/O MoS2 (Lubro-Moly)
Mobil 1 15W-50 | Mobil 1 0W-40
Al 4 | 4
Cr 0 |0
Fe 12 | 16
Cu 8 | 12
Pb 1 | 5
Sn 2 | 0
Mo 198 | 84
Ni 1 | 2
Mn 0 | 0
Ag 0 | 0
Ti 0 | 0
B 48 | 102
Si 5 | 7
Ca 1421 | 2803
Mg 468 | 16
P 869 | 851
Zn 956 | 1006
Ba 0 | 0
How do you know the MoS2 reduced wear? You changed to a different, heavier oil. How do you know the heavier oil wasn't responsible for the reduced wear? Your data does not tell you anything as to the effectiveness of a MoS2 additive.
Ed
Thanks NoTempoLimit, very interesting!
Ed
Even the biggest skeptic would have to admit it clearly didn't hurt anything.
