Curious to what you all have to say/suggest.
Truck is a '97 Isuzu Rodeo with 175k miles; yes, Isuzu's are famous for valve/lifter tapping issues, but not this truck. The only other time I've had tapping issues was prior to waterpump/timing belt failure.
Anyhow, truck is running Maxlife synthetic 5w30, about 3,500 miles into the oci, with a Napa Gold filter; truck does not, has not burned any oil, nor does it have leaks. I simply started using Maxlife because of all the hoopla on this website, but I may change away from it for the following reason.
While I'm currently unemployed, truck has sat for 2-3-4 days at a time stationary. 3 times now, within the last 2 weeks, truck has started up with a moderate valve/lifter tapping problem that lasts for 5-20 seconds or so.
This is a new problem, but it did NOT start until just recently. Oil/filter combination is at least from 2-3 months ago.
My question is - is the maxlife synthetic dripping back into the sump so well that it's leaving the lifters up top dry?
Is the oil - with the 100F temps, proving too thin for this engine? I usually run a 10w30 or even a 5w-40 in summer temps, as this truck is NOTORIUS for thinning a 5w30 into nothing.
The only absolute different things are, using Conoco gas of recently instead of Shell, and being unemployed, meaning truck sits for longer periods between driving.
This is a mild concern, because it occured again just yesterday, and the truck had been driven the day before.
Truck has had a life of Havoline 10w30 and Rotella 5w-40
Suggestions are more then welcome - thank you!
