Lift-Master garage door opener chain lube?
California
What would you guys use on the chain - plain old engine oil or should I use a bike chain lube like White Lightning or Finish Line?
Per there web site
Use a small amount of silicon lubricant to lube the chain, door rollers, bearings, and hinges. The opener does not require additional lubrication. Do not grease the door tracks.
Silicone lubricant is a very poor metal on metal lube.
I would think that a good chain lube would work great.
I use MPC SL-10 oil/grease mixture on my screw drive and door rollers (the metal contact areas, not the rails).
Originally Posted By: EdMcCormick
Per there web site
Maybe, but what they don't tell you is that inside many of these garage door openers is a plastic (nylon) worm gear assembly that will wear out if you don't occasionally add some plastic-safe grease (I use white-lithium grease). I lube mine every few years, 20 year old LiftMaster still working great.
Don't be surprised if you open up the unit and see a bunch of white plastic dust in there, that's what happens if you cycle your door a lot and rely on "factory lube" to last years beyond the warranty.
