License plate fasteners
PA
Hi folks:
Not exactly a hardcore maintenance issue - but what are you guys using for license plate fasteners?
Mine are rusted badly and look like garbage. What should I look at for a replacement? Some guys seem to suggest aluminum (6x16 on a Honda).
Not looking to spend a ton - just want something that isn't going to rust.
It depends on your application.
If you car takes M6 fasteners, use nylon M6 license plate fasteners.
If your are screwing into a plastic bumper, there are stainless license plate screws available.
I use a stainless steel square drive screw to make it harder for some slug to steal my plate. Available at Ace Hardware.
Does not work in Canada, robertson drive is common.
Haha, I was just about to mention that any slug who works construction in canada will laugh at your robertson screws! Most wood screws here are robertsons, only drywall screws are 100% phillips.
I bought a bag of 10 stainless machine screws for like $15 or $20 when I got my personalized plate. I hate rusty plate screws and did not want to ruin my plate. Those screws were pricey, but I have 4 round head allen screws on each plate and it looks super clean!
I grab the stainless ones and put a thick coat of anti-seize or grease on them. Honestly haven't needed to remove them so I can't say it worked. I like the Allen heads just to be a little less common than a Philips. On my bike, I mix it up with two different fastener heads.
I've noticed that most dealers just throw self tapping sheet metal screws in there. I always have to chase the threads with a tap to get my metric screws in.
Originally Posted By: Chester11
Hi folks:
You want stainless. Aluminium will cause galvanic corrosion in the rear plate holder and you will never get them out.
We use stainless here at work and put a small dab of silicone grease on the threads.
We used to use plastic, but the metal in the trunk lid where they screw into would get just a slight amount of rust in the nut, and the plastic bolts would break, nearly every time. We were always having to drill them out.
We switched to stainless about 5 or 6 years ago, never an issue.
Some cars have square holes punched in sheet metal so those expanding plastic square things are required.
I touch black paint on ANY such fastener as it makes them vanish.
So what, Canada has construction workers who like to steal license plates? I drove the van throughout Canada last summer, and no one stole my NC license plate. I also use allen head machine screws on my Ridgeline.
Originally Posted By: skyactiv
This is what I have on both cars since my wife visits her parents in Brooklyn a few times a year.
Once mounted, you can fill in the void with JB Weld. Now it's a real security torx bolt.
