The Check Engine and Vehicle Stability Control lights are lit on my wifes 01 RX-300. They have come on since we have returned from vacation and the car was sitting idle in the drive way while we were gone. I cleared the the lights by pulling the ECM fuse, only to have them return. I have pulled the fuse twice now in the last three days but the lights keep coming back on within a day. This has happened a couple of times over the years and I usually pull the ECM fuse and all is well for a long time,(2 years). This also happened once when I disconnected the battery to do some PM on the car,(tire rotation and brake inspection), then reconnected the battery when the work was completed. The CEL/VSC lights appeared at that time. I disconnected the battery again and the lights dissapeared and I never saw them again til now.
I drove the car over to AutoZone to have them scan the vehicle and code P1130 has showed up. Their print out states...Lack Of HO2S Switch-Adaptive Fuel At Limit. I went on line under Lexus Trouble Codes and found this...Air/Fuel Ratio Sensor Circuit Range/Performance Manfunction(Bank 1 Sensor 1).
Can someone explain this a bit more to me and possibly explain the exact repair procedure. Sounds like an O2 sensor to me? Kind of wondering why the CEL & VSC light come on together each time! .......TIA
CB
CB
