From what I've read, the current synthetic and dino oils are compatible with each other, and you can switch to synthetic and back to dino without any detriment to the engine.
Is there a reason Lexus recommends against doing so?
From Lexus FAQ:
From Lexus FAQ:
Can I use synthetic engine oil in my Lexus vehicle during its break-in period?
Synthetic oil can be used at the first scheduled oil change. Please note that the use of synthetic oil does not extend the recommended oil change intervals. Please refer to the Lexus Owner's Manual Supplement for further information regarding the proper maintenance schedule for your specific vehicle. If synthetic oil is used after that time, it should be the same SAE (Society of Automotive Engineers) weight specification and meet or exceed the API (American Petroleum Institute) grade specifications listed in the Owner's Manual. If synthetic oil is used, we do not recommend longer oil change intervals. Once synthetic oil is used, it is best not to switch back to petroleum-based oil.
