Hey All
I just checked the oil level in my '94 JZZ30 Soarer as I'm doing a long trip this weekend (1200 Kms) and to my delight found that my oil level hasn't changed in 2500Ks.
Using group III synths and HDDEOs my oil consumption was about 1L/5000ks (1 qt/ 3000 miles) and this has been constant for the last 5 years. I've just switched to a predominantly PAO oil (Anglomoil GEO 550 5w40) and I was wondering if anyone else has had a similar experience when switching to a grp IV oil.
I have heard the 1jz engine runs hot and I know the flash point of the new oil i'm using is 250 Degrees c (482F) so is the increased flash point causing this decreased consumption?
Some extra details-
1jz engine is turbocharged, 220K kms (136k miles)
valve stems have (did have?) slight leaks, small puff of smoke after restarting hot but none visible on decel.
last 2 OCIs (5000ks) were Delo400 15w40, Gulf western 10w40 ester syn/ mineral blend. Before this I had changed the rocker cover gaskets and cleaned around the cams (slight deposits)
Some extra details-
