I guess it depends on the material and how bad the condition is that you are trying to fix. Nothing is going to fix cracks though.While doing my car interiors I wondered if allowing the vinyl/rubber protectant to sit for a while or putting it on liberally, would allow it to "soak in" and work/protect better.
Any thoughts on this?
On some mid 2000's Japanese cars you can end up with a sticky and melting dash, it appears protectant exacerbates the issue.
Toyota and Lexus Melting Dashboard Problems Were so Frustrating, Owners Filed a Lawsuit
Toyota and Lexus have an outstanding reputation that has been well-earned over the years. Both are associated with building high-quality vehicles thatwww.motorbiscuit.com
My Avalon has a cracked dash problem in numerous spots. It was a general discussion more on the lines of does this stuff actually penetrate the vinyl/rubber at all or just puts a superficial coating on them.I had one of those 2004 Sienna before,
Toyota actually replaced the dashboard.
It took a good 6 months wait before they replaced it.
It was inherently bad from the factory so no protectant was going to save it or prevented it from cracking.
The replacement was great but who knows since I traded it in 2017.
At any rate, to OP, be more specific in terms of cars make and model and even year.
Otherwise, it will become just a philosophical discussion.
Unless, that is your intended purpose, anyway.
also dont wash your inside windows.. you will be washing them in a day or 2 after evaporation leaves crud on windows.(esp with 303)The best application method to clean and protect interiors is to spray the product on your towel or rag and then wipe the surfaces. Using more product is just wasteful.
I just noticed thatalso dont wash your inside windows.. you will be washing them in a day or 2 after evaporation leaves crud on windows.(esp with 303)
