I have a leaking rear diff that leaks in the bottom left corner no matter what I have tried.
I used a paper gasket with alitttle bit of ultra black rtv to hold it in place. Then it started to leak
In a couple of months. Then picked up a felpro gasket that I followed the instructions on not using any
Rtv and it's still leaking. Both surfaces have been scraped clean of old material and cleaned off with brake cleaner and wiped it dry. I torqued the cover into place per what the manual said which is 28ft lbs. I just saw a couple of drops on the driveway when going to put gas in it. The surfaces are not gouged or has any damage I can see. So I am at a loss
I did not use rtv because the sway bar is very close to the diff over. I have to do a lot of shimmying to get the diff over off.
Thanks
James
Thanks
James
