Leaking AC compressor life....
FL, USA
The AC compressor on the Accord in my sig is leaking oil/freon. I noticed this the other day when I was underneath the car and saw oil on the oil pan, then realized it was flinging off of the AC compressor. I took it in the my mechanic to get their opinion on where the oil was coming from and they did confirm it was leaking from the compressor, he said that it will need a new one but just to run this one until it stops working. As of now the air still blows cold. Has anyone had a leaking compressor before, and if so about how long should I expect this one to last? I will need to save up to get this fixed. Not even sure how much it will be but I know its pricey. Thanks!
My old Volvo leaked. I think it would leak out in about 2 weeks. As for killing it even after 4 years it didn't die. To be honest tho I stopped putting freon in it long before that.
Some where between 5 minutes and 5 years is my guess. Seriously, no telling. Probably be cheaper to replace before it fails completely and sends pieces through the system which could involve replacing more parts.
replace it now. if you wait and it burns up due to no oil it will get real expensive once it contaminates the whole system.it only holds about 5 oz of oil so any visible oil is bad
I would fix it now, if it locks up the black death will spread throughout the whole system and it will cost a lot more to repair.
My Sanden compressor on my Jaguar X-Type has been leaking for the last 5 years. I need to top it off every summer now. Still blows cold here in South Florida. You can probably get a name brand, exactly the same, replacement compressor on eeeebay for 1/4 the price a dealer would charge. It may not have the Honda tag on it, but it will be made by the OEM that provides the units to Honda and will perform/last the same. The Chinese ones are to be avoided.
If it does stop blowing cold (lost it's charge), I'd pull the a/c compressor clutch relay to keep it from trying to cycle. Then get the a/c work done when you can.
My 2000 Accords compressor leaked for a couple of years before needing a can of refrigerant. That was two years ago and it was still working fine when I sold it earlier this year, so they can run a long time or they may fail quickly. I would follow your mechanics advice and run it till it dies. The freon will likely leak out and shut down the compressor on low pressure before it breaks mechanically.
is it leaking visible oil like the op's?
Yes, there is always green oil on the bottom of the compressor. It's not a huge oil leak, but it does exist. It takes about 1/2 can per year.
A friend had his compressor deemed bad/leaking by his Ford dealer....I checked it over and it needed the AC control valve (rear of compressor) and vacuum/recharge system. It works fine to this day and no leaks. I think the green drip coming off the compressor was from the "technician" disconnecting his gauges.
When the compressor fails, you will always be required to flush out the system, replace the drier/accumulator and the expansion valve/orifice tube anyway, so I would just keep using the compressor until it is completely dead.
Here is a question, if its just a slow leak...would it be smart to have the system "recharged"? And is a recharge just an extraction of old fluid and a fill with new fluid?
You can recharge it yourself with a kit from the auto parts store, now that is about as simple as pumping gas
I thought you had to vacuum everything out before refilling, because you DONT know how much to put in, and you could over charge it. Am I right?
Thats if you're opening the system i.e. replacing compressor. Nothing wrong with topping off as needed. I've done it to several cars. Click this link to see the r134a refiller All you do is hook it up to the A/C line (can't remember whether the high or low side, but it only fits on one.) and squeeze the trigger with the A/C on and on full blast. You can also use it to just look at how much PSI is in there. There will be a guide on the side telling you what the PSI should be, it depends on the outside temperature. Edit: guide on the side of the can
If the compressor fails due to leakage, you can just replace it without all that other stuff.
I understand that you are worried that the compressor might cost you big bucks in the future. UNLESS you want to spend big bucks NOW, you need to stop worrying about it UNTIL the A/C stops cooling your car. A lot of people have told you this but apparently you do not want to believe them. Adding too much refrigerant to working system is a BAD idea. You may blindly add it if you find the cooling performance has gone down but still not the correct way to handle it. BUT if your system is cooling properly, DO NOT ADD ANY REFRIGERANT. But it is like giving advice to a wall :-(
Originally Posted By: Vikas
I understand that you are worried that the compressor might cost you big bucks in the future. UNLESS you want to spend big bucks NOW, you need to stop worrying about it UNTIL the A/C stops cooling your car. A lot of people have told you this but apparently you do not want to believe them. Adding too much refrigerant to working system is a BAD idea. You may blindly add it if you find the cooling performance has gone down but still not the correct way to handle it. BUT if your system is cooling properly, DO NOT ADD ANY REFRIGERANT. M But it is like giving advice to a wall :-(
I appreciate the advice, why would I ignore it.
