Leakage under the oil pan
TX
It looks like the oil level sensor on my Land Rover LR2 (w/ a 3.2 Volvo built engine) is leaking. I've search online and I may need an O-Ring to replace the worn out part to resolve this. Do I need to drain the oil to remove the oil level sensor? Thanks
I've seen videos where a shop vac is attached to the oil fill and it hold negative pressure on the crankcase, allowing a sensor change without losing any oil.
Never tried it myself to verify if it works.
I checked some videos on YT and it looks like I'm going to drain the oil. I have an oil extractor. The problem is I have only less than 2000 miles on the current engine oil. I will just re-use it. Thanks
