Our 2009 Corvette (LS3 engine) had a slight oil leak, so the dealership added the GM dye and re-torqued the pan bolts.
The good news is that the leak/seep has disappeared for now. Nothing showing to the naked eye or the black light.
I had the oil changed after the dye had been in there about 1,500 miles (7,700 on the oil, compared to about 6,000 on the previous change; and 37,000 on the engine). Sent a sample to Blackstone as usual. The results showed my lead had increased from 7 to 13, and tin increased from 2 to 5. But copper was virtually identical, despite the extra miles.
Blackstone said they doubted the lead came from the dye (they said nothing aboout the tin), more likely it was a particle wipe from a bearing. But I seem to recall a previous post somewhere where a user reported getting increased metal, (lead?) when he added dye to his oil. And if there was a particle wipe, wouldn't that also show more copper?
Any comments?
Any comments?
