LC in diff oils
JHZR2
Staff member
New Jersey
Hi,
Im curious if anyone has used LC in diff oil, and if youniticed any change. The diff in my BMW has a small case, and so gets quite hot.
Thanks,
JMH
I would not use LC with a differential fluid unless you're going to do a quick flush.
I.E, use it only for a very short time to clean if you suspect a "dirty diffy."
Most diffy fluids have dispersants and detergents to keep crud suspended, so just replacing the fluid is usually good enough.
well, Id be using SF diff oil anyway, so I'm glad you replied
JMH
