diff/trans fluid change frequency for mule
I've done the front diff and rear transmission on my mule for the past few years every year despite being driven for less than 300 miles/year. Does anyone think running it for two year interval at this mileage would make any difference in longevity if it's stored covered and outside? I use HPL for the diff/transmissionmission fwiw. TIA.
Thanks for the responses. I am planning on changing the engine oil soon (ish) and will try a Donaldson filter (P169071 - assuming it fits) and I'll likely switch to every other year HPL oil changes too.
Any reason to avoid using this filter and plan?
I looked that P169071 filter up on rockauto and it said it does not have an anti-drainback valve. I don't know if that is a factor in your application or not. It appears to be a Motorcraft FL1A equivalent, otherwise.
I emailed Donaldson and they said it did. I think the package says so too. Let me see if I can find that email/spec info....but definitely WOULD matter how this thing is mounted.
@ripcord of course I can't find it now 😐 and donaldson's website indicates "no" on the spec sheet for ADBV. I emailed them again. I remember it having some sort of rubber/silicone/insert material here opposite the holes in the mounting side of the filters. I THINK that would indicate ADBV though I'm far from an expert. I'll close the loop with a pic of the filter to hopefully get some idea on whether or not it's a good idea or not. Again, thank you (y)
I'm guessing that FL1A sized filter is significantly over sized from stock? That would make the absence of an anti-drainback valve even more significant.
