- Joined
- Nov 18, 2024
- Messages
- 204
It’s good but IMO Seal n Shine is easier to apply and also seems to shine and resist dust much better.
Layering can work after setup but before complete curing. It improves the density of the film build. The problem is no one knows when this magic time period is for Griot’s 3-in-1. It is typically an hour with a bottled coating. Of course it depends on chemistry and diminishing returns apply.It's why layering is probably not necessary or beneficial. Its bonds and works so well, it is essentially repelling itself when adding the second coat. The second coat will simply ensure a uniform application and cover anything you might have missed.
During the set up, ScottHD followed manufacturer instructions for application. Some give instructions on wait time, others don't give any information for layering. Griots did not.Layering can work after setup but before complete curing. It improves the density of the film build. The problem is no one knows when this magic time period is for Griot’s 3-in-1. It is typically an hour with a bottled coating.
Here is the application (first video in the series):
I think it will have to be shorter for a product like Griot’s. These sprays cure fast. I tried this with Fireball Pirouette on an acrylic shower mirror and I got noticeably better (insane) hydrophobics with two layers after about 15 min. I use this mirror kind of as a test and waiting longer didn’t seem to help and made it worse, but I wasn’t able to get that same result again without polishing it for whatever reason. Pirouette is a solvent based product not water based like Griot’s so I wonder if two layers actually works better or worse because of that. It’s possible water based products don’t layer well because the carrier can’t “wet” the surface.He only waited 1 hour each coat. I think this is probably why…
Nope. For optimal performance it needs to be cured 24 hours.I think it will have to be shorter for a product like Griot’s. These sprays cure fast. I tried this with Fireball Pirouette on an acrylic shower mirror and I got noticeably better (insane) hydrophobics with two layers after about 15 min. I use this mirror kind of as a test and waiting longer didn’t seem to help and made it worse, but I wasn’t able to get that same result again without polishing it for whatever reason. Pirouette is a solvent based product not water based like Griot’s so I wonder if two layers actually works better or worse because of that. It’s possible water based products don’t layer well because the carrier can’t “wet” the surface.
I meant for layering as in a second layer after the first. The majority of curing occurs quickly. Especially compared to a bottled coating. For layering you do not want a fully cured surface.Nope. For optimal performance it needs to be cured 24 hours.
Yes, I was talking about layering. I did emailed Griots and they stated before applying the second layer, allow it to cure at least 16-18 hours. This is coming directly from customer service.I meant for layering as in a second layer after the first. The majority of curing occurs quickly. Especially compared to a bottled coating. For layering you do not want a fully cured surface.
That’s contrary to the advice of almost every other ceramic spray / coating and what basics I know of polysiloxane coatings.Yes, I was talking about layering. I did emailed Griots and they stated before applying the second layer, allow it to cure at least 16-18 hours. This is coming directly from customer service.
