I've got a guy with a thousand-year-old rider. The fuel line is routed right across the top of the muffler. The guy put a new in-line fuel filter within 3/4 inch of the muffler and it gets very hot. Can the heat cause a vapor lock in the filter? The fuel will come into the filter if you put your hand over the barrel of the carb, but runs out and doesn't replenish itself if you don't. I told him I don't think the carb is acting up because the engine is running so well. It's an 8 HP Briggs on a rear engine Lawnboy rider.
