This is not oil related, but I had a strange experience with the battery on my riding mower last weekend. I pulled the John Deere D140 out of winter hibernation on Sunday. It spends its winters in an unheated shed. It wouldn't start without 1/2 hour on a battery charger. After getting it started I drove it up to my garage to top off the tires with air. Then it refused to restart, even after another 1/2 hour on the charger. I did manage to jump start it but found the battery so weak that the PTO clutch wouldn't stay engaged. Off to Walmart for a battery...
The good folks at Walmart seem to know nothing about stock rotation, meaning I found a 230 CCA U1 battery with a 3/19 date code right up front, while the rest of their stock had date codes going back as far as 8 months. The original battery was rated 190 CCA, so I figured 230 was more than adequate. I installed the new battery and connected the charger for 20 minutes, just to be sure. After that I turned the key and nothing, other than headlights, not even a click. Next I tried jumping in and still nothing. At this point dinner was calling, so I decided to sleep on it.
In the morning I tried jumping it again, but still nothing. Called the John Deer dealer, who immediately blamed the battery and said that I should have used a 300 CCA battery. I found that to be less than credible, given that a 190 CCA battery came out. Running out of ideas, I disconnected the new battery and ran my jumper cables to it. Presto! She fired right up. Then I reconnected the new battery, and presto, she fired right up. Let it sit 20 minutes and once again she fired right up. Put her back in the shed, went to work, came home and again she started right up. I guess all is well that ends well, but why did it refuse to start on the first few attempts?
