This is the only way I've found to put a larger filter on the 2020+ L5P - you must also buy the fuel cooler relocation kit. The 2020+ L5P has a larger oil cooler and a smaller filter was the trade-off. There simply isn't room for a larger filter without the relocation kit. I have the kit sitting on my workbench and will install it sometime soon. It's a simple and well made kit.
2020+ GM 6.6L Duramax High-Efficiency Engine Oil Filter (replaces AC Delco PF26) *This oversize filter requires the use of the 114002700 PPE Fuel Pump Relocation Bracket (2020-2024 L5P)This oversized PPE Engine Oil Filter has 2 times the specially engineered filter media equaling 522 square...
ppepower.com
Fuel cooler relocation kit:
Fuel Coolant Pump Relocation Kit This kit replaces the factory heater coolant pump mounting bracket and moves the pump further away from the oil filter so that the PPE High Efficiency 2020+ L5P Deep Oil Filter (114000750) can be installed. Using the large
ppepower.com
