Large Price Difference In PCV Valves ??
Even worse. I had to replace a valve cover on an M52 motor and it was around $700 for the new oem part a few years ago. Must be $1k + if they have another great idea built in.
I had no issue paying $30 for the Nissan pcv on our juke.
ZF has a similar deal with their 8-speed transmissions. You have to replace the drain pan when you do a fluid change.
They sell the whole thing as a kit. Pan, and filter. I think it runs a couple of hundred bucks, plus the fluid. Probably more now.
Not that bad. Depending on the engine as well a Genuine vs OEM the VC is $150 -$300.
The PCV repair is around $25
