Guys, hope you can help me solve a problem. Car in question is a 2001 Nissan Sentra SE with a 2.0L engine. BTW, it does not have any CEL or SES codes.
On cold start ups in the morning and sometimes when the car has been parked for an hour or so, it sputters when first started. Idle is erratic and sometimes RPM drops low enough that engine dies. When I try to step on the gas pedal to give it some gas, I have to do it very gently, or the engine will die. Usually after driving for a few minutes, the car can idle on its own.
Right after I move off, engine usually sputters a little, bucks a little and hesitates on each low gear change. When I step on the gas, engine is very slow to respond, even if I floor it.
I had this problem last year too, right after I changed the battery. It miraculously returned to normal after I think I drove over a bumpy road. Recently I had to disconnect the battery for some electrical work and the same thing happened on re-connection.
I have done the idle air control valve re-learn procedure but situation has not changed. Could this problem be due to a out of spec mass airflow sensor (MAF) or a throttle position sensor? I would like to solve this problem as soon as possible as I am going to take the car out for a road trip.
Thanks,
Julian
Thanks,
Julian
