Want a WIX? add a 5 in front of the NAPA #
Want a NAPA .knock off the 5 from in front of the Wix #.
Baldwin B179 is what the Baldwin X-ref puked out
That X-refs in Wix to 51064
51064
UPC Number: 765809510647
Principal Application: Bolen, Case, Hitachi, Jacobsen, I-R, John Deere, Kubota, Vermeer, Yanmar, Kia, Hyundai Transmissions
All Applications
Style: Spin-On Lube Filter
Service: Lube/Transmission
Type: Full Flow
Media: Paper
Height: 2.944
Outer Diameter Top: 3.243
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
51358
UPC Number: 765809513587
Principal Application: Honda Motorcycles + Industrial Engines, I-R, Komatsu, Kubota, Kia (95-05)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.782
Outer Diameter Top: 2.685
By-Pass Valve Setting-PSI: 8
Gasket Diameters
Attached 2.420 2.230 0.150
