After reading all the wisdom on Ktmtalk.com about how best to look after the engine on my '06 KTM 525 EXC while Dual Sporting, and now stumbling on this forum I am totally confused!
The conventional approach seems to be;
1)The engine runs hot and has very little oil in the combined Engine/gearbox/wet clutch.
2) Add a additional oil cooler/reservoir to increase the volume of oil and lower the oil temperature.
3) Make the bike run richer to help with bringing the engine temp. down.
From what I can see on this forum, the main culprit is the combined gearbox/engine though.
If the viscosity shears down due to the gears so quickly, will adding the oil cooler/reservoir help at all?
Additionally, I see that most recommendations are to use Rotella oil because it is cheap and then can be changed frequently.
Rotella doesn't seem to be sold by Shell in South Africa, so I'm not sure what to use as an alternative?
