Originally Posted by Phishin
Originally Posted by doitmyself
My Krowned vehicle has never dripped as much as KrisZ's picture shows. I've been getting it done for five years, the first two in Windsor and now at Monroe, MI. Both places seem to not cut corners and even with asking the guy to spend a few more minutes (material) on it this fifth year, it did not drip like KrisZ's.
The material is pretty thin and you can only apply it until run off occurs. Its not like you can layer it on several thicknesses. I'm just not sure how you could apply it heavier/thicker. Having said that, it does seem to build somewhat more of a layer on the unwashed areas after a few years of application.
The disadvantage of oil sprays is the dirt accumulation mess. If you are obsessive about a pristine engine bay, etc., an oil spray will not agree with you.
Regarding timing, Krown's theory is that rust occurs worst during warm weather, so it is better to get it done in the spring to get the most protection. This is opposite of most people thinking you should get it done in the fall just before the onslaught of salty roads. They also imply that even though it might look washed off underneath, there is still a microscopic layer of protection, also different to most thinking that thicker is better. Stated elsewhere, I get mine sprayed in late spring and I use an aerosol can of the product to touch up exposed underneath areas in late fall to make me feel better.
doitmyself.....did you find great service and knowledge at the Monroe, MI shop? I'm glad to hear that yours doesn't drip like KrisZ's either.
Your logic was the same as what I was thinking: The underside can only "hold" onto so much Krown....over spraying so much only allows more run-off. I'm really confident that I received really good covered on my truck, regardless of the lack of an oily mess shown above.
If done properly, imo, one should see some dripping in some places and have no/zero dry spots anywhere on the undercarriage. Also, one should see some oil on their bottom door sills and all the seams around the trunk and hood. 68 degrees is hot enough for it to drip.
