This is a couple years old but I figured I'd post it anyways. Long story short is the GF took her car to a car wash establishment in that does oil changes also. Very impressive, large, clean looking facilities. I was told that they use High Performance Lubricants for their oil change lube. After close to a couple thousand miles she tells me it's making a weird noise every now and then and it will be down on power. I guess the oil light would flicker sometimes while this was happening too. I listen to it and it sounds like the cam chain is slapping around to me. I pull an oil sample and also pull the filter. The filter housing is supposed to have a support tube that the filter slides over and this was missing allowing the filter to partially collapse. I'm guessing maybe it was going into bypass and that wasn't allowing the cam chain tensioner to work properly. I got a new Toyota housing, filter and some TGMO oil and it appeared to take care of the problem. She didn't drive it for about 3 weeks while we were waiting on the oil sample results hoping to minimize any internal damage if there was any. Nothing in the oil report showed anything abnormal and 2 years later everything is still good. So the 2000 mile oci on this report is without the support tube and then the 8000 mile sample is with the TGMO 0w20. It has around 130k on it now so I'll try to pull sample at the next oil change. I have a picture of the filter that I'll try to post also.
