Originally Posted By: bigjl
Originally Posted By: mongo161
It would also help to disclose the type of material is used in the BMW gaskets?
If I'm not mistaken.......
A while back someone mentioned that the Mercedes, which most likely includes all German made cars, was using an older type of material that promoted leaks in their vehicles. I would have to think that that problem has been fixed.
Maybe someone with a lot of experience with this issue can chime on the gasket issue with older MB.BMW. VW, Audi etc.....
And you think this was correct why exactly?
I would hardly think you can generalise with every manufacturer in a Country.
As that would obviously mean that all US manufacturers all use the same materials at all times.
And I would really have doubts if Mercedes were to use inferior gasket materials, gaskets can and do leak after many years of use and after having gone through many heat cycles.
Though I am not saying Mercedes don't make mistakes, the drop in build quality and use of poor quality rust proofing during the mid to late ninties and early part of the "naughties"
Certainly shows that.
I think it was me he was referencing and it was BMW, not Mercedes I was speaking of. They use rubber instead of silicone for their valve cover gaskets, which hardens and leaks over time. Most of the North American manufacturers use silicone rubber, at least I know Ford does.
