Well I tend to do stupid things and this is a new one for me. I have a z trak with a 25hp Kohler Command Pro commercial engine on it, It has 415 hours on it. I went to mow tonight for about 40 minutes and when I got done and pulled it in the garage I shut it off and as I was going to clean cooling fan intake as I do every time when im done mowing I see a black T shirt on top of the air intake. My heart stopped. How it got there was from my own stupidity, I wont make that mistake again.
I instinctively pulled the t shirt off immediately and started the mower up and let it idle to cool it off. The oil cooler felt hotter than normal and I put some water on it from the condensation of my iced tea cup and it boiled off fairly quickly. From my nitro RC Days I estimate that the oil cooler temperature was between 230 and 240 degrees based on the speed at which the water boiled off.
I ran inside to get my infrared gun and I got a temperature of 221 degrees on the oil filter, this is after the engine was idling a minute or so.
I ran it some more and let it cool down and I experimented with the shirt blocking the air intake. I would say depending on how it was laying on there it was blocking at least 50 percent of the airflow. The ambient temps were 75 degrees with no sun as it was almost dark out.
I checked the oil which is mobil1 10w30 synthetic and it smelled ok and looked ok.
I think I dodged a bullet, but time will tell I suppose. I am going to change the oil tomorrow since it is almost due anyway, and I will keep moving along. Time will tell if I damaged anything. She definitely ran a little hot, at least compared to what it normally runs, but maybe it was not much different than mowing on a 100 degree day, I don't know. the cylinder heads definitely had airflow, albeit not what they should have had, it was a cotton T so it was like a filter I suppose.
Now as I mow I reach back and feel the air exhausted from the oil cooler from time to time because I am OCD like that and I know I reached back there at least once while mowing with the restriction and at that point I was 25 minutes into mowing and I didn't notice anything that raised any alarms so hopefully It wasn't too hot.
Argh.... Its always something. Maybe that Mobil one was worth it after all....
