Kohler 5400 Series
Originally Posted By: walk23
Bought a ZT with the new Kohler 19 hp engine. Any thoughts and/or recommendations ?
Thanks
I don't know..... did you do any research BEFORE buying it?
Kohler Courage engines are absolute garbage
Read the manual as to oil change interval and other service and you will be fine. Usually manufactures suggest that the first fill oil be changed a 5 to 10 hours and then 100 hours per change. Ed
+1
Most likely just change the oil early first.
Like noted it could be the first 5 -10 hours and bigger kohlers are 25 hrs.
https://power.kohler.com/na-en/engines/5400-series
Don't go by the Manual for oil changes in the beginning. When I bought my 2 Honda lawnmowers through the years I would do the lawn 1 time, 1 hour and dump the oil. It had a silver glidder look to it with 1 hour. Good to get the first crosshatching "knock offs" out of there. Then I would do the lawn 2 more times and 2 hours and it was drained again. Glidder there too. Then at 5 times and after that I would go the rest of the season in Minnesota. Then the next year I would do a mid season drain and after that I would go the full season on an oil change. I use synthetic after the first season. I spent a whole $9 on oil. With no filter there is no way I am leaving oil in with only one early oil change. And 5 to 10 hours is way too long for a first dump in my opinion.Not for the massive price of $9 for three early flushes.
