What is the color of the spark plug? If it is white, that is caused from a lean fuel mixture. Lean is caused either from air leaks or most likey gummed up jets. You can also test to see if it runs better with the choke on. This is also an indication the mixture is too lean.
Remove the carb, float bowl, and the brass jets screwed into the carb below the float bowl. Spray the jets and passages with carb cleaner. I also poke a wire through the holes in the jets with a wire I pull from a wire brush. This wire is flexible enough not to damage or enlargen the holes.
I am not sure how common this is but the carb in my pressure washer has a steel plug and a rubber seat (image below). The rubber swelled, thus lowering the float to the point the fuel level in the bowl was below the jets. This was the cause of the lean condition in my case. I purchased replacements on ebay and problem solved. I could have also just replaced the carb but I was confident with my diagnosis.
