Kohler 22HP, 7000 series engine ?
West Virginia...
Hello everyone, I need to replace the gas filter on my lawn tractor, hoping there is a cross references filter out there, part# KH-25-050-22-S1.....
Is there a cross references on the air filter too ?..
Pretty much any inline fuel filter for OPE engines with a fuel pump will work.
As for the air filter, I wouldn’t use anything other than a Kohler filter.
If you are looking for something cheaper check on line, there are perfectly good ones there for less$$
These are 30 Micron rated fuel filters that are spec'd for "Extended Life" Briggs Engines. If it's good for B&S it should be good for Kohler too. Yours has a fuel pump? Should be no problem. I've never had to clean the carburetor or any trouble in 121 hours/10 years using these on my Craftsman Rider but I use sta-bil & berryman too though.
https://www.amazon.com/Briggs-Stratton-695666-Extended-Selected/dp/B0038U3JHK/
