group 2 oils are readily available for 2.50 per quart
group 3 oils are readily available for 3.50 - 4.00 per quart
so there is an extra 4-5$ per oil change, or if you use 50% synth, and extra 2-2.50 per oil change. 2 bucks is in my budget range. 5w30 oil is all group 2, 5w20 is group 2+. so i run
a 50:50 group 2 group 3 mix, which is close enough and just costs an extra couple of bucks per change, basically chump change or the cost of a couple cups of coffee. i've been brown bagging my lunch, and i get a better lunch that way, and save 2$ a day over cafeteria food. basically motor oil is so cheap, they are practically giving it away. might as well at least use 50% synth, it's only 2$ extra per change. 5 bucks extra gets the full synth, means the engine has as thin an oil as possible at start up, and many of us take short trips, and start up is a significant source of wear, so i am quite happy to treat my engine that way. as far as group 4/5 oils go, i've been reading that their "tenacity" is low, meaning the film strength is actually not as good as a conventional oil. also mobil oils seem to not give any better UOA than just SuperTech, so I use SuperTech knowing that I get an honest group 3, or Napa, another honest group 3. even though group 3 is just "pseudosynthetic" it is still a much more uniform molecular structure, so the molecules don't get tangled up with each other and slide past one another more easily, plus the pour point is lower, and it needs less viscosity improvers, and is more shear stable, so for an extra 2-5$, considering I'm driving a vehicle worth 25,000$, this represents 1/10,000 part of the value of the vehicle, a very tiny tiny insurance policy.
