Fuel pump went out in the 454 Suburban. Repeated attempts to start it using old gas, new gas, starter fluid brought fail. Had fuel pump changed. Electric pump, in the tank. Mechanic says it now has a lower end knock from oil diluted with gas. It started ten seconds into his test run after installing the new pump. He shut it off, we pushed it home.
I'm changing the oil before the truck gets driven, have a filter, buying oil at the local c-store, hope they have something not nondetergent. This is (was?) our only running vehicle. Is there anything else I can do to quiet the knock, anything I can add to the oil or fuel to keep my wife from throwing a fit, or the engine from throwing a rod? Oil pressure was 50-60lbs when he looked at the gauge after hearing the noise and right before shutting it down. I've never seen it above 40 really, unless it was ice cold outside.
