KN HP-1002 NC Miata
Maryland
Off a customers car. Approximately 2k miles on M1 5w20 and 2 years on. It took quite a bit of effort to remove it, hence the damaged can.
Replaced with Valvoline 5w20 and Napa Proformer 21348MP which is China made.
Thanks. Bypass poppet valve at the base end?
Looks like the filter could have stayed. Maybe the oil too. But I understand.
What year Miata?
You gonna inspect the pleats for metal or other contaminants? Of course that requires cutting open the filter carefully to avoid contaminating it.
Louvers look good. Hard to really tell but it looks like there may be some ridges on the leaf spring. Thanks for the C&P.
Only changed because I was asked to while performing other work. Car is a 2006.
I pryed thru some of the pleats, found nothing. I felt no need to wick for days and cut out.
