Kia oil filter specs.
Mojave Desert
OEM oil filter specs for a kia 2.4l pn 26300-35503
Who manufactures them? Kia?
what is the media type?
micron rating?
by-pass valve rating?
burst pressure?
flow rate?
bursting pressure?
media surface area?
pleat count?
Drain back value material?
I have a few on hand and would be willing to mail one off to get the data however I have no idea who I would send it to. I found a thread on another site where someone has the specs for a lot of filters and it is an awesome reference.
I have read the TSB about using the factory filter, and im going to be a hard head and ignore it. I would like to go with a WIX filter but only if it is comparable for flow rate, and bypass valve rating. The TSB the dealer showed me uses an example of someone using a super cheapo filter with no bypass valve and terrible design.. call me a rebal or stupid but I would like something a little better if it is out ther…
I have also looked at the dual remote bypass filters and I would really like to go with it however. Im a little unsure of the factory oil pump being able to support this without having a staging pump for start up pressure and that would add almost another $300 to the cost of the bypass filter set up. Any ideas or info would be awesome.
AMSOIL
Manufacturer: WIX
Part Number: Ea046 (deprecated)
Media Type: Nano-Fiber (Donaldson Synteq)
Micron Rating: 20μm Absolute
By-pass Valve Rating: 14psi
Flow Rate: 9-11gpm
Burst Pressure: 330psi
Media Surface Area: 77 sq in
Pleat Count: 35
Drain Back Value Material: Nitrile
Country of Manufacture: Mexico
other awesome oil filter site referance:
http://forums.evolutionm.net/evo-engine-...g63t-4b11t.html
couldn't tell you any exact specs, but they are made by Dongwoo, a subsidiary of Mann. Antidrainback is silicone. Same filter as the Hyundai. It will fit any Hyundai or Kia that takes a spin on can, as well as any Mitsubishi or Chrysler with a GEMA motor.
Part Number: 51334
UPC Number: 765809513341
Principle Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-13), Isuzu (85-04), Kia (01-13), Mercury (87-91), Mitsubishi (89-98), Subaru (87-13) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed:
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 21
Gasket Diameters Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
source
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=51334
i pulled the numbers on the first post from the site that had the cut away... first post was wrong sorry.
