JHZR2
Staff member
Hi,
I got a new dyna glo kerosene heater to warm the main living space of my apartment (1200 sf, so quite sizable) when Im home. The heat pump and ducting stinks bigtime, and is more or less a waste of money in operation. Its a shame that I have no choice but to use it for AC, but in the winter, I figure Id augment and minimize the use.
I got my heater, set it up, let the wick absorb fuel, etc. All was well. I got it started, extinguished it, repeated same a few times, and then let it burn outside for a good long while to let the oils and whatnot burn off, per the instructions.
One thing that I noticed however is that when I extinguish it, there is a slight flame at the bottom that is 'noisy' (I hear it pulling/gasping air) and very jumpy. It is quite small, multi-colored whiteish bluish, and does not do much, but its there after Ive extinguished the system. How long should such a flame last? Mine is there for about 30 seconds... I dont know if this is good or bad, and if its bad, how to fix it.
Also, Ive noticed that using it inside makes a slightly stinky interior of my apartment. Ive tried cracking a window, but without flow, it does not do much... When I shut down the unit, especially them it gives off some more odorous offgas. I know better now to take the thing outside when Im done using it and turn it off - but is there any other good way to keep much odor from coming off, especially after shutdown? I use crystal clear kerosene and have the flame adjusted perfectly per the instructions - red with a tiny blue peak coming from the top.
Any info or suggestions would be appreciated. Thanks!
JMH
JMH
