Kenworth Selects New Factory Fill Oil
Of course, most fleets operate like the company I work for and the 10w30 will quickly be dumped at the first OCI and replaced with cheap bulk dino 15w40 "Because we've always done it that way".
Originally Posted By: stockrex
ahhh, 10w30, finally....
I bet it will bring tears to dnewton's eyes.
True.
Sadly, more true.
However, what will the difference be? The engine should still last nearly 1 million miles
True.
I stocked up some shell at menards many moons back right after you posted the OCI :-)
Sadly, more true.
maybe the manufacturer can require 10w30...
Hi,
KD0AXS - Yes you are correct. It's very hard to change entrenched cultures and this is very true amongst Trucking Fleets. Probably more so in the US/Canada and Australia ythan in Europe
Kenworth of course fit a range of engines from a number of Manufacturers and according the the purchaser's requirements. Have no doubt that the engine Manufacurer's requirements will be paramount
The Delo range of HDEOs has long been one of the Fleet favorites (typically with fuel supply arrangements) and they are a great performer in service
Originally Posted By: martinq
How long before we see some 5w or 0w HDEO showing up in NA?
Well, we may have to wait some time for 0w-20 HDEOs getting anywhere, but there are plenty of 0w-XX and 5w-XX HDEOs already. There are 0w-30s, 0w-40s, 5w-40s, and I have seen some 5w30 HDEOs with older API specs.
A million miles is at the low end. Engine manufacturers are shooting for a million miles before the first rebuild.
I have seen many European oils in both 0w30 an 5w30 for HDEO use in the EU truck market.
It's been that way for a number of years.
The Caterpillar HEUI engines and 6.6L engine have been coming from the factory with 10w30 for the last few years. I don't know about their larger engines.
And that Kenworth factory fill of 10w30 is right now targeted toward the new Paccar MX engines specifically. Not sure that will be the case with any KW with a Cummins ISX in it. I know that Detroit is targeting having the DD 13 and 15 series engines filled with 10w30 or 5w30 oils.
Here is an interesting read:
10w-30 HDEO
Volvo and Renault trucks share the same engines and Renault now use 10w30 as FF oils.Renault Truck oils are manufactured by Total:
Renault Truck oils
...while Volvo's are XOM products.
Iveco(FIAT Powertrain) is tied to SeleniaFL(owned by Petronas now):
http://web.iveco.com/czech/collections/c...c_Oil_Range.pdf
...and DAF (Paccar) has been relying on Texaco(Chevron) and Total products.
Mercedes used Shell oils in their HD range(Signia 10w-40 and Rimula Ultra 5w30 in Euro-4 and 5 engines) . I think it is Shell Rimula R6 LME that is used now in the new om471(DD 13's twin).
Coming back from Bismarck last summer in an ISX powered International ProStar my oil temperature stayed right at 225. I hope Kenworth is trying to keep oil temps lower. My hybrid SUV running Pennzoil Ultra 5w-20 at 165 degrees is operating on a higher viscosity of oil than the International at 225 with Citgo Syndurance 5w-40. Imagine how thin a 10w30 would be at 225....
That is often the goal. Most will go 700,000-1,000,000. Then one overhaul at that mileage will probably be the last. Not many trucks go long enough to need another overhaul, the rest of the truck is usually shot by then. However it could be rebuilt and put in a glider.
Our oil rep is a retired UPS fleet manager. They ran their Mack's on 30k OCIs with Delo and ran them to 1.6 million with no overhauls or bearings then scrapped them. When they switched to running 10w30 they gained 1% in fuel economy.
They could, but they list in the article that different weight motor oils can be spec'd for a factory fill by the customer.
http://finance.yahoo.com/news/kenworth-upgrades-factory-fill-engine-170000253.html
Originally Posted By: bigt61
It's all about fuel economy these days.
I missed the "Delo Dinner" our dealer had a little while back, one of the main topics was the new oil spec that is coming up soon. The entire focus on the new oil seems to be fuel economy. At this point it is said to not be backwards compatible.
They are dropping RPM's little by little to help with fuel as well. Volvo is down to cruising at 1100rpms. Detroit is getting down there too. Have not heard where Paccar is at. Cummins just dropped to 1300rpm for next year. They expect to drop more to meet the standards.
Originally Posted By: dparm
Interesting. What was the previous FF?
Chevron Delo Multigrade 15W40 has been the factory fill since 1989 for Paccar. Our 96 T800 still has the factory fill sticker on it.
In 2005 they started using Delo ELC for factory fill coolant. At that time it was the factory fill or option at every truck mfg.
Well lately their larger on road engines have been non-existant.
Enough of their off road stuff comes with 10w30 though.
They're probably the same ones draining at 15,000 miles as well. "Oil is cheaper than an overhaul". Those people really bug me. This is the one site I can come to and finally relax when it comes to stuff like that. Outside of it though, especially farming boards, the 200hr/3,000 miles/15,000 mile oil change is considered gold to many. Even though OEM's are reccomending 5,000-10,000 on the cars, 500-600hrs on tractors and 30,000-50,000 miles on OTR trucks.
Its the stubborn American way.
I was talking to our Volvo Construction Equipment service manager the other day about their new loaders. I brought up the "Eco Pedal" feature they have. Essentially it applies variable resistance to the pedal to try to "naturally" make you run lower RPMs, you can still overcome it, but if you are not paying attention it will push your foot back.
He also mentioned that in their excavators there is a High/Med/Low for the engine RPM. However everywhere but in the USA, the High position does nothing. Medium is where the engine runs best and produces the power needed, yet the Americans thought it didn't have any power unless they could hear the engine screaming, so they did what they had to do to keep themselves competitive and offered a high throttle setting.
When I hear stuff like that, I really have a hard time really thinking it is valid. 1% of a semi truck getting between 7 and 8 mpg (that is darn good on a long haul class 8 commercial truck. Industry average is just over 6 mpg) is still less than one tenth. There are so many variables with a class 8 truck, that there is almost no way to determine if the oil or something else caused any increase. And those that categorically make claims like above, have never hauled any freight year round in their life.
On the surface, it would appear to make sense that a lower viscosity oil would be more fuel efficient. How that plays out in the real world is another thing. Type of tires, the wear on them, the tread design will make more of a difference in fuel economy. Blends of diesel, time of year, etc will also be an issue. Of course, seasonal weather with varying winds, also contribute considerably. Life cycle of air filtration. Wheel bearing tightness will offset fuel economy more than the 1% that is claimed being gained by using a particular engine oil. Even the gap between the cab and trailer can make more of difference than an oil ever could. Controlled lab settings are fun to see what happens. But anyone who has been trucking for more than 30 days, knows that controlled lab and track settings hardly compare to the realities of trucking. And if one digs a little deeper, when a 1% improvement is claimed in commercial trucking, there is usually an agenda being pushed.
