Originally Posted By: The Critic
Originally Posted By: daman
Yes SL,CI...and that API isnt that old so...
Kendall's on the GM 6094M,GM 4718M Corvette spec sheet then?
SL is quite old, as SN/GF-5 is coming in a few months. You're talking about two generations ago.
Kendall's GT-1 Ultimate Synthetic 5w30 is on the GM approval list for 4718M.
Their GT-1 Full Synthetic, GT-1 High-Performance Synthetic Blend and GT-1 Ultimate Synthetic products are all on the GM approval list for 6094M.
http://www.gm.com/corporate/responsibility/environment/maintenance/gm_approved_engine_oils.pdf
Plus this oil is kind of unproven,how many used oil analysis are there here of this oil? not many i can find,the OP wanted opinions i gave him mine.
I would trust the extensive testing conducted by the additive manufacturer and/or GM before I trust one or two used oil analysis by the questionable labs that people often use.
Oh come on now we need used oil analysis to prove a oil IS worthy,you know that.
Originally Posted By: ottotheclown
So, in some tractors in Bad Ax you found that Kendall does not measure up to Mobil 1??? Be still my heart!!!
Get it right it's Bax Ax
e
and your absolutely righ, im my findings it just did not,and when your running expensive equipment you don't [censored] around!!
