Kendall GT1 High Mileage
the South
I'm currently running Pennzoil High Mileage 5w30 in my 2 Subaru Outbacks. One is the 2.5 H4, and the other is a 3.0 H6. Both have a few minor weeps and leaks that I'm trying High Mileage to see if it'll help.
Anyone have experience with Kendall's High Mileage oil? The specs look ok.
http://www.phillips66lubricants.com/documents/conoco/industrial_oils/Ken%20GT-1%20High%20Mileage%20SB%20MO%20(Ti)%20TDSw%20815902.pdf
Would be for about 5000 mile OCI to start with.
I don't have any experience with the Kendall HM but I am currently running Pennzoil Platinum HM 5w30 in two vehicles. It is thin for grade. The butt dyno says it's great. I'll have used oil analysis done at the end of the OCI's. If you like the current Pennzoil High Mileage but want synthetic then I think that it's a good choice.
It's now readily available at WalMart so I'd expect that we'll get more used oil analysis for it in the coming months.
I have a 2001 Explorer Sport Trac that has been leaking from the oil filter adapter for quite some time. Then I started using Kendall High Mileage 5W30 and the leak has almost completely stopped. I'm going to stick with it for awhile it's good oil.
It looks like I can get it for $3.25/quart delivered. Not an amazing deal, but not terrible for a syn blend.
I get it from my local distributor for about $48.89 for a 12qt case, so you're getting a pretty good price. Go for it!
