Anyone have any experience with this gear oil?
I'm considering putting it in the front axle of my tractor. I'm a bit worried about just running GL-4 rated tractor fluid as its in 4wd alot and obviously its all high high load and low speed running and the oil is darkening up after 50 hrs.
I kept the initial fill in for 50hrs and it was fairly dark but no chunks or shavings, now the second run of GL-4 tractor fluid is supposed to go to 400hrs but even after 50hrs the oil is darkening up.
The kendal 80w140 is GL-5 rated and MT-1 as well so I don't think there's any way I can hurt anything in the front axle with this oil.
I guess my question boils down too, is a synthetic GL-5 oil going to be far better than a dino GL-4 oil in low speed, high load situations?
